First build last part advice
Approximate Purchase Date: Before the Christmas
Budget Range: (1000-1250$)
System Usage from Most to Least Important: Gaming(MMO),Video Editing, Surfing
Parts Not Required: keyboard, mouse, monitor, speakers, OS)
Preferred Website(s) for Parts: Newegg.ca
Country of Origin: Canada
Parts Preferences: None
Overclocking: Maybe
SLI or Crossfire: Not now
Monitor Resolution: 1920x1080
Here are the part I already own:
GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - 200$
Intel Core i7-950 Bloomfield 3.06GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor BX80601950 - 300$
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - 50$
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLIReady CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - 100$
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C9 - 85$
TOTAL = 735
I basicly need to buy an Storage Media and a Graphic Card and a Cd/Dvd burner.
Concerning the GPU, I heard the Nvidia perform better with Intel PCU, is it true ?
I'm asking myself how could I optimize this 450-500$. Should i get an SSD-HDD with a cheaper GPU ? An high-end graphic card ? Should I buy an aftermarket Cpu cooler ?
Thanks in advance for your answer and sorry for my english, it's not my main language.
1 answer Last reply
More about first build part advice
  1. ^ It is not completely true that only Nvidia cards do well with Intel CPUs, even ATI are good enough, but if you will be using Adobe Premier for Video stuffs, then going with Nvidia cards would be advantageous as CUDA accelerated Mercury Playback Engine very well...
    GTX 470
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16814500157
    SSD
    OCZ Vertex 2 60GB
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16820227550
    HDD
    Samsung F3 1TB
    http://www.newegg.ca/Product/Product.aspx?Item=N82E16822152185
New Build Systems
