Solved
My PSU won't power my HD 5670
Hey guys,
I recently purchased a XFX HD 5670.
And I installed right away when I got it delivered from UPS.
Okay,
I have to tell you the Specs of my computer so you guys can a get idea.
CPU- Celeron 420 @1.60GHz
RAM- 2GB
PSU- 300w (I know the HD 5670 requires 400w)
I think I made the mistake when I though that my 300w PSU could power the 5670.
My current PSU only has 20 power connectors to the motherboard.
I was doing some reading and I found that the extra 4 pins are for powering the graphics (I believe)
I thought my card was DOA when I installed it because I got no signal to my monitor.
And the fan on the graphics card was spinning. (I hope that I didn't damage the graphics card)
I just want to know if am correct, my current power supply set up.
And if once I get a new power supply,
My graphics card will function properly.
I only have $45 to spend for a for a new power supply.
Can anyone help me look for a new power supply?
Thanks!
15 answers Last reply Best Answer
More about power 5670
  1. Best answer
  2. Thanks!
    I'll look at the specs and review them with some buddies of mines.
    Thanks a lot mate,
    Thats a great find!
    I was looking at these two earlier, I liked them because of the price.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182075
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182022
    But the reviews kind of concerned me.
  3. there are only a few good rosewill units the green is one of their better lines
    there are a few more but you'll be good using the green 430
    another option
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139017
    $20 after rebate even tho the rosewill is slightly better its a good deal
  4. rosewill has just a few alright models, for the price the ocz does better, i never trusted rosewill and never will, theres still lower end of the blacklist of bad powersupplies
    another option
    http://www.newegg.com/Product/Prod [...] 6817139017
    Yeah,
    I noticed that not many people like Rosewill power supplies.
    I saw the reviews for that Corsair,
    And they are really bad man.
    iceclock said:
    Ouch,
    I cannot purchase that one mate.
    I think am going with this one.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817182202
    Am on a really tight budget man,
    I wished that I had more spare money,
    But I don't :(
  6. you'll be fine with that rosewill,its rated even a bit higher then the corsair 28 amp 12v vs 33 amps for the rosewill,the cx430 is actually rated more like a 380 watt psu
  7. Okay,
    I will go over this with my parents tomorrow,
    Since they help me out a lot.
    Thanks so much for all your help man!
  8. aight good luck :)
  9. MarcosFabian said:
    thats a crappy 300 watt thats been over rated
  10. raidmax is junk when it comes to ps, they where very few good rated raidmax ps, and that one is no exception
  11. Best answer selected by MarcosFabian.
Power Supplies HD Power Components Product
