Hi, I'm going to have a PC built around Sapphire Radeon 5850 Vapor-X crossfire.
(http://www.newegg.com/Product/Product.aspx?Item=N82E16814102872 )
I'll probably have to order the PC without the Vapor-X card then add the card after the PC arrives,
At first I 'll just install one Sapphire Vapor-x card, then when I need more GPU power I'll buy
another Sapphire Radeon Vapor-X card. Why the Vapor-X? Because, according to toms hardware
reviews it's stable, runs cool, has mature drivers, eyeinfinity and uses relatively little power.
I've read the card is very big >10.5" in length with power connectors extending from the back of the card.
which size case and m/b do I need? What else do i need to know when selecting hardware for these cards?
I currently have a very nice 24" Samsung 1900x1200 monitor all of the 24" monitors i see now are 1900x1080
can I add one of these monitors to my new PC or do I need to repalce my 1900x1200 monitor with two 1900x1080p monitors?
Did I fail to ask needed information?
Thanks,
Mike
Thanks,
Mike
