hi all,
i had a problem booting my system with two stick of ram, but could boot with one.
Here is the post.
http://www.tomshardware.co.uk/forum/forum2.php?config=tomshardwareuk.inc&cat=13&post=300230&page=1&p=1&sondage=0&owntopic=1&trash=0&trash_post=0&print=0&numreponse=0"e_only=0&new=0&nojs=0
I have got my new memory corsair cmp4gx3m2b1600c8 and it is still the same. It states that this memory is for phenom II systems.
I have tried everything that i know of that was in the post above.
Has anyone else got any other ideas that might help.
**edit**
ok i just changed the speed to 1333mhz and the voltage to 1.65 with both modules in and it got to the desktop but then rebooted.
what does this mean. i need to try and change the timings but my timings are 8-8-8-24 and there is about 15 in the bios any ideas which ones i need to change.
I have also updated the bios to 2302 from 2202.
thanks
Thanks
Here is the post.
**edit**
thanks
Thanks
