Approximate Purchase Date: This Month
Budget Range: $2000
System Usage from Most to Least Important: Gaming / Surfing Internet / Music / Movies
Parts Not Required: Keyboard, Mouse, Monitor
Preferred Website(s) for Parts: Newegg.com, (All I've used thus far / Newb)
Country of Origin: United States
Parts Preferences: N/A
Overclocking: Maybe
SLI or Crossfire: Maybe/Eventually
Monitor Resolution: 1920x1080
Additional Comments: I'm just looking for the best PC I can get on a budget of $2000. Also, I've been scanning the forums for information pertaining to Sandy Bridge. Which, I'm not entirely sure if I can even wait but if I could. Would the cost of Sandy Bridge / Compatible Mobo severely dent what I could spend on other areas? Seeing as this is my first build I was thinking I'd just upgrade to a new CPU/Mobo setup down the line. (That would be feasible, wouldn't it?) What would put a staple in the plan of upgrading those areas? (As in, what other areas would need to be upgraded or changed?) So, I guess that is the only comments I have to add for now.
Intel Core i5-760 Lynnfield 2.8GHz 8MB $205
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive $70
NZXT Phantom PHAN-001WT White Steel / Plastic ATX Full Tower Computer Case $140
Budget Range: $2000
Overclocking: Maybe
