Eyefinity help
So I was looking for the active dp to dvi dongle when i found these
http://cgi.ebay.com/ATI-Active-DisplayPort-Single-Link-DVI-Adapter-/380269680086?pt=LH_DefaultDomain_0&hash=item5889d6d5d6#ht_2095wt_1302
http://www.amazon.co.jp/Sapphire-DisplayPort-Single-Link-Adapter-44000-02-40R/dp/B0044CKAUU/ref=sr_1_2?ie=UTF8&s=electronics&qid=1287047010&sr=8-2
Would either of these two work? I thought you had to connect it via usb to power the dongle? Thanks in advance and sorry for the links.
2 answers Last reply
More about eyefinity help
  1. Yes, anyone of these will work perfectly fine.
    Personally I'd go for the Sapphire one..... I have suggested it to quite a few too.
  2. So basically they made it so that there would be no need for the usb connector? Wow, thanks a lot man. Will get the sapphire one then. Can't wait!
Graphics Cards Graphics
