I have been looking into building an htpc to go along with my new led tv. I am going to need to purchase all of the hardware except for a hard disk. I snagged a Samsung Spinpoint F3 1TB 7200rpm Hard Drive for $51 at SuperBiiz.com Here is what I came up with, any suggestions or improvements are greatly appreciated.
Case: nMEDIAPC Black Aluminum / Acrylic / Steel HTPC 6000B
http://www.newegg.com/Product/Product.aspx?item=N82E16811204037
PSU: Antec NEO ECO 400C 400W
http://www.newegg.com/Product/Product.aspx?item=N82E16817371029
CPU/GPU: AMD Athlon II X3 445 Rana 3.1GHz
Evga GeForce GT 240 512MB 128-bit DDR5
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.553994
Ram: A-DATA Gaming Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333G
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211410
Blue Ray Drive:LITE-ON Black 4X BD-ROM 8X DVD-ROM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106325
Mobo/Win7: ECS Black Series A785GM-M AM3 AMD 785G HDMI Micro ATX AMD Motherboard
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.552632
Total $510.93 plus 20 bucks shipping before rebates ($90). So end cost is around ~$440
I am a little concerned if that case will be able to hold the psu.
I had my eye on a radeon 5570 since it has dx11 and hd audio through hdmi but I couldn't find any gddr5 versions and since my receiver doesn't have hdmi inputs I would have to run the audio off the motherboard S/PDIF Optical out. I have never done this with hd audio and was wondering if this would be a problem.
Thanks for reading and any help.
