Hi Toms I have a XFX 5870 znfc Is this the reference or non reference model? I am looking for a waterblock for it and notice there are 2 types of waterblocks depending on which model. Thanks...
Your card is non reference.I wonder why you want to watercool it.They run really cool even with stock cooler.If you are planning crazy overclock then beware i donot think it supports voltage tweaking.Your card is lighting fast even at stock speed.
Imo there is no need to watercool it for moderate overclocking.Save that money and buy a second 5870.
I don't need to... True, as I am currently setting a water cooled setup and figured with the rad I am getting it will support it. You are probably right, my card hits 60c max so it does not get that hot. Maybe I will save that $100 for a second card.
