Approximate Purchase Date: This weekend hopefully.
Budget Range: $700-$800 before rebates
System Usage from Most to Least Important: Gaming and CAD software
Parts Not Required: Operating system (Win 7 Professional)
Preferred Website(s) for Parts: newegg.com
Country of Origin: US
Overclocking: Maybe
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1080
Additional Comments: Here's what I have so far for my build:
Intel Core i5-760
http://www.microcenter.com/single_product_results.phtml?product_id=0341729
$169.99
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA CD/DVD Burner - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118039
$19.99
NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058
$49.99
$44.99 after promo code
$34.99 after mail in rebate
Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model 996770
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226095
$99.99
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.569069
$149.98 Combo
$139.98 after mail in rebate
10% off the PSU with promo code
XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
ASRock H55M-LE LGA 1156 Intel H55 Micro ATX Intel Motherboard
$273.98 Combo
$233.98 after mail in rebate
Total:
$777.44 Before rebates
$763.44 after instant promo codes
$703.44 after mail in rebates
Is this a good build? Is everything compatible? Will the i5 bottleneck the 5850? Do you guys have any suggestions on how to cut costs a bit more?
Thanks!
Overclocking: Maybe
Intel Core i5-760
$169.99
$19.99
$49.99
$99.99
$149.98 Combo
$273.98 Combo
Total:
Thanks!
