I'm having severe problems with my PC and I can't figure out what's wrong with it.
I have a dual boot system, WinXP Pro and W7 Ult 64 bit, and W7 started to basically "lag", when installing apps, downloading stuff, and so on. It would kind of hang, and cause other apps to stop responding, but they would eventually recover, then go dead again, then back to normal, etc.
I got a couple of BSOD's, but only in W7, so I'm wondering if my RAM is bad. I recently "sort of" recovered from losing my entire boot drive (1 gig of data, gone for good), that no recovery tool could recover the data. It wouldn't boot, and I could not recover any data with any recovery tool.
I've run HD tests, even removed the "faulty" HD in question, reinstalled both OS's, and I just got another BSOD, this time saying "Memory Management", but I've had many different BSODs that were all different.
I have 6 gigs of RAM, and I'm thinking the higher RAM is bad (it's happened before), but I'm not sure what is causing the memory to go bad. I have a very well ventilated case and am only moderately OC-ing, and have just lowered the OC, to see if that was the problem. It doesn't seem to be the problem.
The crashes are inconsistent, and very different things keep happening, so it's really hard to say for sure, what's going on.
When I try a boot disk, that OS (usually a Linux release) never crashes, and all HD tests and memory tests, using different apps, even the 64 bit W7 repair disk memory tester - extended mode, detects 0 errors.
Does the W7 repair disk test ALL of the RAM you have?
Anyone have any other thoughts?
I've of course scanned for viruses, did disk scans, etc, and I do find some disk errors here and there (not surface errors), but fixing them doesn't seem to help.
