Case fans: mobo vs molex ?
Last response: in Components
- SolvedI have a Rosewill Challenger case with 3 fans but my mobo only has 2 chassis headers. If I run 1 fan on molex would that affec Forum
- SolvedHelp solving a no POST issue on new build - logic says SYSFAN on Mobo, PSU.Molex or case fans issue????? Forum
- SolvedIs case fan installed through molex from psu or mobo system fan? Forum
- Case fans not working when molex cable connected to mobo Forum
- New Case Fans Don't Spin off Molex, but DO Off Mobo? Forum
- SolvedSomeone school me real quick on case fan connections. 4-pin vs molex Forum
- SolvedNeed help with connecting fans: 5 case fans all using Molex connectors. Forum
- SolvedProblem with Case FANS + MOLEX Forum
- SolvedMolex case fans to motherboard Forum
- SolvedPowering case fans w/Molex and motherboard Forum
- My case fans have a molex looking connection and my motherboard has only one 4 pin fan header. All the rest are 3. Forum
- SolvedHooking up 2 case fans on a molex connector Forum
- Solved4-Pin Molex For Case Fans? Forum
- SolvedCan I plug case fans directly into my molex connectors? Forum
- Case fans have molex connectors no way to connect to psu. Forum
- SolvedQuery about 4-pin molex cable to handle case fans Forum
- SolvedSimple question about case fans being connected via molex & noise Forum
- can you connect 3 pin case fans to 4 pin molex connectors Forum
- SolvedCase takes molex for each fan? Forum
- Question about coolermaster case fans and molex connectors Forum
- More resources
Read discussions in other Components categories
