Active display port doesnt work help
mrvr6
4
iv got a sapphire active display port with the intention of running 3 monitors from my 2 5870s. i cant get it to work it wont detect all 3 monitors in ccc any 2 will work but not 3 i assume its my fault any ideas??
mrvr6
4
all 3 are connected to 1 card 2 via the normal connectors they both work fine iv got the other connected to the display port using the sapphire active display port adaptor this is the 1 that doesnt do anything at all its as if it isnt plugged in iv checked and dbl checked it is plugged in correctly including the usb power lead.
ps iv checked the monitor itself and thats fine
