Here is a link to the case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119195
Here is a link to the Radeon 4650 gpu:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102843&cm_re=4650-_-14-102-843-_-Product
I can't really tell if this gpu will fit in this case because the gpu has no dimension specs. :/
How would I go about determining the size of this gpu and whether it will actually fit?
Thanks guys.
Thanks guys.
