Help for new work PC
Last response: in Systems
Approximate Purchase Date: January 2011.
Budget Range: $$500.00 CDN taxes included.
System Usage from Most to Least Important: Operating Windows 7 and Office 2007 with a CRT dual monitor setup. Surfing the internet. Writing emails.
Parts Not Required: keyboard, mouse, monitor, printer.
Preferred Website(s) for Parts: newegg.ca (canadian site)
Country of Origin: Canada
Parts Preferences: none
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1600x1200
Additional Comments: This computer main function is for work. It uses a dual CRT monitor setup. The goal is to be able to perform tasks without any slowness.
More about : work
CPU: AMD Athlon II X3 450 Rana 3.2GHz
http://www.newegg.ca/Product/Product.aspx?Item=N82E1681...
MOBO: ASUS M4A88T-M/USB3 AM3 AMD 880G HDMI USB 3.0
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333
http://www.newegg.ca/Product/Product.aspx?Item=N82E1682...
HDD: SAMSUNG Spinpoint F3 500GB 7200RPM 16MB Cache SATA 3.0Gb/s
GPU: GIGABYTE Radeon HD 5670 1GB 128-bit GDDR5
PSU: Antec Basiq BP430 430W 80+
CASE: COOLER MASTER Elite
DVD: ASUS Black 24X SATA
DVI-VGA: Rexus DVI-VGA DVI Male Dual-link to VGA Female Adapter
TOTAL: 497$
Related ressources
Looks like it would be hella cheaper to just get an adapter. So if I were to get the adapter, I would not notice any performence decrease over a GPU dual monitor setup?
if that is the case looks like the build above with an adapter is the cheapest build so far.
Ask the community
