Sound Drivers won't work Maximus IV Gene-Z
solinvictus01
72
Hello,
I just installed Windows 7 on my new gaming pc but the sound won't work at all. I tried everything. Installing the sound drivers, going into Device Manager to manually install my sound card but nothing works.
Help please! Thank you!
solinvictus01
72
Hi! Problem is fixed. It wasn't enabled in the BIOS. ASUS Tech support is not very bright. I spent half hour with them trying to figure it out and the rep did not know what to do.
Thanks for the responses.
