ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
NZXT M59 - 001BK Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058
CORSAIR XMS3 8GB (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model CMX8GX3M4B1333C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145279
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
GIGABYTE GA-880GMA-UD2H AM3 AMD 880G HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.564586
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Suppl
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.569069
Planning to get a 6850 later, will live with onboard graphics for now. Mostly word processing and internet use for now.
Total: $526.77
Trying to keep it around $500 not including graphics card.
Thanks in advance for any suggestions! Just wanted to make sure I didn't forget anything or buy incompatible parts.
Or should I go with this RAM? http://www.newegg.com/Product/Product.aspx?Item=N82E16820231308
Total: $526.77
