Power supply failed to jump start, is it broken?
I used the paperclip trick (one end into green and other into black) to see if the power supply is working and I plugged it in, nothing happens. I'm working on a friend's computer that doesn't even start up, just the power led comes on what I power it up and that's it, the fans don't spin up, it doesn't make a sound, nothing. So does that mean the psu is dead since the paperclip trick failed? I have done it before so it's not like I did something wrong as far as I'm aware.
tl;dr
Paperclip trick failed to start up psu
Is the cause of computer not working the psu?
Edit: I have a spare power supply laying around, could I try plugging that in to see if the computer will start up? It won't fit so I'll have to keep case open and situate the psu on it somehow. I think I will need to ground it to case somehow?
2 answers Last reply
More about power supply failed jump start broken
  1. If the paper clip did not work then the PSU is broken, a computer needs a working PSU to work!
  2. use that spare psu, you dont need to ground it just to test it. just plug t in and try turning it on.
Power Supplies Computers Components
