Hey, this will be my very first build and I've read up on the various topics and necessary components and hopefully someone will be able to check that my parts are all compatible and an efficient use of my well earned dollars. My build is as follows...
Case - Cooler Master HAF 932
http://www.canadacomputers.com/product_info.php?cPath=6_111&item_id=019666
Motherboard - Asus M4A78T-E Socket AM3 AMD 790GX
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4444096&CatId=5534
CPU - AMD Phenom II X4 965
http://www.canadacomputers.com/product_info.php?cPath=4_64&item_id=027384
RAM - Cosair 4GB x2 RAM 1333MHz
http://www.canadacomputers.com/product_info.php?cPath=24_311_312_611&item_id=032949
Harddrive - Seagate Barracuda 7200.12 SATA 3.0Gb/s (1TB) 32MB Cache
http://www.canadacomputers.com/product_info.php?cPath=15_210_212&item_id=021907
PSU - Ultra X4 750-Watt Modular Power Supply
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=4558896&CatId=2533
DVD Burner - Asus DRW-24B1ST 24X
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=6078414&CatId=1624
Video Card - Sapphire HD 6870
http://www.canadacomputers.com/product_info.php?cPath=43_557_558&item_id=034444
CPU Cooler - Arctic Cooling Freezer XTREME Rev.2
http://www.canadacomputers.com/product_info.php?cPath=8_129&item_id=022082
An additional note is that I plan to utilize CrossfireX later down the road but it's not in my immediate need or budget during the initial build. I will be most likely running Windows 7 64-bit OS and will be using this computer as a gaming PC plus regular web surfing, word/spreadsheet processing as well. It will be hooked up to my LCD TV and I'll only be using a single monitor for the time being.
Many Thanks!!!
Many Thanks!!!
