Solved
System under $400 thoughts?
CPU: AMD Athlon II X4 640 Propus 3.0GHz
GPU: Galaxy GeForce GTX 460 1gb
Mobo: MSI AM3 AMD 880G HDMI Micro ATX AMD
Ram: G.SKILL Ripjaws Series 4GB (2 x 2GB)
PSU:500 watt(built in to case[rosewill brand])
OS: Windows 7 Ultimate
Cooling: Stock (This is temporary)
Please respond soon...X-Mas is almost here
Plus...Would this system be "Crysis Worthy" ? I mean like Very High settings at a smooth framerate...
14 answers Last reply Best Answer
More about system thoughts
  1. ^ Good build except the PSU,...
    And whether it would play Crysis @ Very High depends on the resolution of the monitor that you would be using,...
    http://www.guru3d.com/article/geforce-gtx-460-review/21
  2. I suggest swapping CPU from X4 640 to X3 455 and from GTX 460 to 6870. You can unlock the 4th core of CPU if in case u need more from it.
    Also you need to specify which resolution r u gonna be running and wats ur total budget for this build and location?
  3. This isnt doing Crysis at very High at anything over 16x10, dont think ti will be smooth at 16x10 with aa imho
    Well I usually play at 1600x900 and my budget was like $400...
    It's a huge upgrade from my previous system
    CPU: Intel Pentium 4 2.8ghz
    GPU: XFX 9500GT 1gb
    Mobo: ?
    PSU: 350 watt
    OS: windows 7
    Cooling: stock
  5. You will be fine with your specs. I would change the PSU eventually. With the Stock PSU you might want to drop the cost of the CPU to the X3 like stated before and change the GPU to a more energy efficient one.
  6. Where are you affording that for $400 key me in please
  7. Best answer
    THis si a decent mid-low range build and should handle crysis at 16x10 nicely.
  8. CPU+MOBO: AMD Athlon II X3 450 Rana 3.2GHz + BIOSTAR TA880GB+ AM3 AMD 880G HDMI (129$)
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.566265
    RAM: G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 1333 (49$)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231274
    GPU: HIS H685F1GD Radeon HD 6850 1GB 256-bit GDDR5 (179$)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814161348
    PSU: Antec Basiq BP500U 500W Continuous Power (49$)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371004
    CASE: NZXT GAMMA Classic Series (39$)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811146061
    TOTAL: 448$
    Above components will run all current games in High details on ur resolution.
  9. mianmars said:
    Above components will run nearly all current games in High details on ur resolution.
    Fixed
    Well I found the combo deal from Newegg.com it came with EVERYTHING but the GPU and HDD plus the OS
    The GPU is from Tigerdirect.com... Originally 209.99 ( I think) but the price drops $40 with the rebate
  11. I must also mention...My computer now can run Crysis on medium/high but only at a maximum of like 5-20 fps. And that is with a low end 9500gt and a P4 2.8ghz HyperThreaded
  12. ^ USeless post.
  13. Go For The X3 455
  14. Best answer selected by TheDigitalRob.
New Build AMD Systems Product
