I bought a dell S2309W a while back.I was using it with a system consisting geforce 9600gt,recently I found my old pc consisting fx 5200,I was hoping to hook the sytem of fx 5200 with the monitor along with the system of 9600gt.
The s2309w has both dvi-d and vga inputs,and fx 5200 has a vga output and the 9600 gt has dvi-d output.My question is that can I use both the systems simultaneously with the monitor with out doing any damage to it?Lets say both my systems are running and hooked with the s2309w,so basicaly I can switch one system to other using the monitors builtin input selection menu.But feeding the monitor data from two different systems simultaneously might damage it or so I fear,as I am no expert in this field.
I don't want to use a kvm switch if the built in function works with out damaging the monitor.Any help regarding this problem is welcome.
thank you.
thank you.
