Power Outage...OH NO
Hey guys,
So yesterday I weathered two power outages that happened for no real apparent reason..perhaps a car accident. At any rate, I went to bed and everything was fine. However, I woke up this morning and saw that we had ANOTHER power outage. I tried to turn my computer on a few hours later and...it wouldnt turn on at all, though one time I did hear a minor crackling sound X_X. I flipped the red fuse switch on the back of the power supply, turned it on, and it powered the fans, the vid card fan, and the green led is lit on the mobo. However, the light in the front that normally indicates the computer being on is not powered and there is no bootup at all. No video, nothing.
At first guess, does this sound like a partially fried power supply or is it something more insidious? I thought the front lights were HDD lights so I'm worried my hard drives got fried, but I tried hooking up another one and I still didnt see a light.
Any comments would be greatly appreciated.
10 answers Last reply
More about power outage
  1. First of all what PSU do you have? Usually the little red switch is not a fuse but a voltage selector between 230volt and 115volt input, unless you are meaning the on/off switch.
  2. Ah crap it might be a volt switch then..the only reason I thought it was a fuse was because it didnt work until I flipped it.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817152028&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=3463938&SID=
    Thats my power supply
  3. Well most likely it is bad (now they don't like wrong input Voltage)! If you did not have the computer on during the power outage it is most likely only the PSU that failed. Replace it with a quality unit with active pfc (no selector switch) this one has gotten great reviews http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
  4. thanks! Ok...heres the weird thing though roll...I just flipped the switch back and turned it on...everything is magically working. No idea what the heck is going on. It was LITERALLY just COMPLETELY dead.
  5. Somehow you PSU lived when flipping the red switch.. you get really really lucky.
  6. Really? Wow...its about time I got some luck x_x. I have another post I have been using to talk to a few great dudes about another problem or two I've been having, so to NOT have to deal with this one is a HUGE relief.
  7. Flipping the voltage select doesn't necessarily kill the PSU. Generally only really crappy ones die from that. Most others will either A) fail to power on, or B) will power on but fail to issue a PWR OK signal to the motherboard, so you'll get fans and drives spinning up, but no POST.
    Flipping the switch you probably reset the unit (good sign has some sort of protection built in) so you where lucky this time.
  9. If you are plugged into 115 volts and flip the voltage selector switch to 230 volts and try to boot, nothing will happen. The PC just willl not work.
    The opposite is not true. You will fry something.
  10. Oh. Ok. Thanks a lot guys. It's been working fine all day. I think I might have to start unplugging the computer at night before I go to bed....honestly can't handle that stress anymore haha
Power Supplies Power Outage Components Product
