G
Guest
Guest
Primary interest is gaming - prob. things like CoD, ME2, Fallout, etc. I'm transitioning from console to PC so not too familiar with newer games. I have a monitor (23") already. Would the build below be okay?
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
59.95
Antec EarthWatts EA-500D Green 500W ATX12V v2.3 / EPS12V 80 PLUS BRONZE Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371035
69.99
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
54.99
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
19.99
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102873
136.99
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
59.99
AMD Athlon II X4 640 Propus 3.0GHz 4 x 512KB L2 Cache Socket AM3 95W Quad-Core Desktop Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
99.99
Windows 7 +
MSI 870A-G54 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.552540
184.98
Total: 686.97
Is there a better mobo for the Athlon II X4 640? I see a lot of recs for a couple of Gigabyte ones.
Also, I tried adding one of the mobo/CPU bundles from micro Center (http://www.microcenter.com/specials/promotions/AMDbundlePROMO.html) to my cart, but the discounted price doesn't show up. Any reason why? If I can get it to work, which bundle would you suggest for my price range?
Thanks!!!
59.95
69.99
54.99
19.99
136.99
59.99
99.99
Windows 7 +
184.98
Total: 686.97
Thanks!!!
