Trouble shooting a comp that won't power up, and I really don't want to RMA again. However I'm also expecting to need to.
As in title, this is my first time to build a comp. I unfortunately had a DOA power supply, failed the paperclip trick. Now I think the mobo is DOA as well, also due to fun power issues. When I plug in the 24 pin connection it will light up for a second...then nothing. If I then pull it out then replug it the same will happen.
If it somehow matters:
PSU: Corsair CMPSU-750TX 750W
[strike]Motherboard[/strike]Processor: Intel Core i5-760 Lynnfield
Thanks for any help, I definitely appreciate it.
*Edit* Opps, that would be a processor not a motherboard.
This would be my motherboard: Biostar T5 XE CFX-SLI LGA
Probably should have gone higher end on that, but it was on an incredible sale.
