Solved
Will front audio ports use sound card quality? Best sound card?
Hi,
I'm using my mobo sound card right now (asrock 870-extreme3). I want to get a sound card for $40-75 on newegg. I'm also wondering if my front audio ports (on antec 300) will have the same sound card quality once I install it? What do I need? Or do I just plug in the HD port on the motherboard?
2 answers Last reply Best Answer
More about will front audio ports sound card quality sound card
  1. Best answer
    You can just plug the HD-audio connector to your motherboard. This will give you the onboard card running when you plug in headphones. This should have the same quality you have with the onboard card right now.
    If you do get a sound card, check the specs to make sure it has a front port audio or HD audio connector on it. Some older cards did not have that connector leaving the front port audio useless. As long as the sound card has that plug, you can plug that cable into the new sound card and it should work fine and at good quality.
  2. Best answer selected by funkifresh.
Sound Cards Audio Components
