Sign-in / Sign-up
Low Frame Rates on radeon hd 5870
  • Radeon
  • HD
  • Graphics
Last response: in Graphics Cards
October 19, 2010 9:31:38 PM
Just bought a studio xps 9100 came with windows 7 64 bit, 9 gigs of ram, intel i7 running at 3.20 ghz and the hd 5870. in most games my fps stays at around 50 if i put on high graphics is that normal?
More about : low frame rates radeon 5870
October 19, 2010 9:36:22 PM
No, imo you should have better performance.
Have u updated ur drivers to the latest version?
m
l
October 19, 2010 9:39:52 PM
ya have catalyst v 10.9 and drivers version 8.7, and the game i notice it on the most is dragon age origins using fraps tells me im anywhere from 42 to 50 fps
m
l
October 19, 2010 9:58:09 PM
Hmm looking at benchmarks with a 4GHz i7 and and 5870 u should deffenatly get higher FPS.
How high did u put ur AA?
m
l
October 19, 2010 10:05:58 PM
Did you turn vsynch off when you tested? Under what settings, what games, and what fps?
m
l
October 19, 2010 10:06:22 PM
what resolution?
m
l
October 20, 2010 12:31:47 AM
i turn vsynch off either way i should have prolly about 60 no? 60hz screen, also my resolution is 1920x1080, as far as AA in what the gpu or the game? either way in catalyst i have 8x and same in game.
m
l
October 20, 2010 3:37:13 AM
any1 else have any ideas?
m
l
October 20, 2010 3:48:52 AM
Right click on CCC-this lets your games,apps apply IQ settings, which is what you want.
3d settings
standard settings
optimal performance
m
l
October 20, 2010 5:19:53 AM
im more interested in using my card at full capacity, i mean it really should according to specs and the amount i paid for, anything else that may work?
m
l
October 20, 2010 7:31:47 PM
Overheating, and also did you buy the GFX card seperate if so are you sure your PSU can handle it? and its not just a cheap brand?
m
l
October 21, 2010 1:54:28 AM
it all came with the pc, studio xps 9100 the gpu stays at about 50 degrees c, and cpu at 40 ish
m
l
October 21, 2010 2:03:31 AM
I don't know what that statement means ?
Are you referring to you putting 8X AA on in CCC ? If your not willing to test and provide more details, games, settings, results, how are we supposed to help you.
First off, that AA setting is a bad idea. You use CCC to FORCE AA in rare cases where the game does not have its own implementation.
A example is Starcraft II, anything over 4xAA brings AMD cards to their knees.
m
l
October 21, 2010 2:19:41 AM
my aa settings are set to use application settings, i have AI disabled and mipmap to max
m
l
