Hello,
I have a Corsair 700D case and I want to install 3 exhaust case fans on top of it. I've decided on Scythe Gentle Typhoon series. I want them to be very quiet.
Notes
1. I will not be water cooling it.
2. System to be used primarily for professional work, some gaming.
3. Hardware - Intel DX58SO2 mobo, Intel i7-970 CPU, Asus 6970 video card (one card for now, two cards if I need it), 3 monitors, high-end sound card, 2 hard drives)
QUESTIONS
1. Which Scythe fan would you recommend from Gentle Typhoon series (500, 800, 1,150, 1,450, or 1,850 RPM)?
Remembering - I will have 3 of these on top of my case and I want them to be very quiet and at the same time help reduce heat
2. Is it worth it to have variable fan speed given my setup?
3. Now, the 3 fans on top would be better used for exhaust, right? Should I even consider using them as intake? Why or why not?
As always thanks,
Jack500
Notes
QUESTIONS
As always thanks,
Jack500
