Closed
Is this enough power for me? I don't trust calculator
Last response: in Components
CPU-i5 2500k---------------------------------------------$248/$252
MOTHERBOARD-AsRock P67 Extreme4---------------$176
GRAPHICS CARD-GTX570-------------------------------$379
CASE-Antec 300------------------------------------------$55 (Questionable)
PSU-Antec TruePower 750W---------------------------$139 (Questionable)
RAM-8G 1600 G.Skill-Ripjaws--------------------------$121 (Questionable)
MONITOR-LG 2353V-PF 23"----------------------------$169
HDD-Seagate SATA2 3.5" 1TB--------------------------$59
OS-Window 7----------------------------------------------$99
DVD RW-SATA Blu-Ray Combo Samsung-------------$59
CPU Cooler-CoolerMaster Hyper212+----------------$33
Keyboard- Sidewinder X4-------------------------------$44
Antec TruePower 750W <-------------------- Is this much power too much? Will it be safe to go with Antec EarthWatt 650?
And while you're at it please take a moment to examine and comment on my build :)
More about : power trust calculator
Power supply Expert
If you have no plans for a second card the 650W should be sufficient. There's also any extra fans or peripherals, but it looks like you'll be fine.
If you are hesitating because of the cost of the 750W, I wouldn't because you really want to get a quality PSU that can handle any overclocking or expansions in the future. I recommend getting the 750W as it will be with you for the next 5 years.
Related ressources
so 650W is too small for mild overclocking?
Power supply Master
No 650w is fine for any overclocking. 750w is only necessary for futureproofing against adding a second graphics card. Look for Corsair, Antec, Seasonic, PC Power and Cooling,XFX, or Enermax for top quality.
Don't forget OCZ's Z-series & Fatal1ty.
Ask the community
