Closed
Q: Connecting Dual/Multi-Monitor On 2-Way SLI + Dedicated PhysX Card
Quote:
Are you trying to do "Surround Vision" or just have several monitors?
Good question, currently I am running 2-Way SLI, with dual monitors, and setup varies depending on if I am working productivity software or gaming. If gaming, then the game title determines if I'll enable Surround 2D or just game on a single monitor. Having just recently purchased a third card for PhysX, my question becomes do I need change the connection, by connecting the second monitor to the PhysX card?
Best solution
No, the Physx card is not used to output a video signal and 2D Surround Vision only supports three monitors (two in the primary card and the third in the secondary) at this time.
Best answer selected by MingtheMerciless.
n
nAdditionally, I found the answer as well, partially through looking a the FAQ for 3D Surround on Nvidia. Which shows a third GPU, for additional displays, though I am not sure if it can still be ran as a dedicated PhysX card in the control panel. However, this means, if 3 monitors are used for 2D/3D Surround, then two or more additional monitors can be added with a 3rd card.
n
nhttp://www.nvidia.com/object/3dv-system-requirements-su...
n
n
Ask the community
