Bobster8881
4
Hey,
I have a PC and the motherboard has died, its a Abit IN9 32X-MAX Wi-Fi Motherboard, and no longer available to purchase. I'm ok with computer stuff but have never bought a motherboard before.
I don't want to have to change any other components, but can't find a motherboard to buy, I want one as cheap as I can get!
The RAM i have is 2gb, two 2gb DDR2 modules.
Graphics card is Geforce 8800 GTX, I have two of these boards (They require pci-e x16 i believe)
The processor is a core 2 quad, I believe the model is Q6600 but don't have the box
PSU is 1000w
I also have a TV tuner card i would like to be able to keep using.
Anyway, if someone could suggest a motherboard (and justification would be great so I know what to look for next time!) that would be fantastic!
Oh, my case can hold 6 HDD's, not sure if any connectivity is needed for those!
Bobster8881
4
Would this do the trick? My main concern is I have 4 fans, this can only support 3?
www.gigabyte.com/products/product-page.aspx?pid=2553
