hi is everything compatible here do you forsee any problems? I live in South africa and this is a budget build for photoshop and web design these are the components
Intel® Core™ i7 870 - 2.93GHz Quad Core, Socket 1156, 8MB L3, Intel DMI Interface, 45nm, x64 Support Intel VT, 3 Year Warranty
MSI® Intel H55 Chipset P31 - Intel i3/i5/i7 Socket 1156 series @ Front Side Bus : QPI 6.4GT/s - PS/2 KB&Mouse
Transcend® JetRam™ High-Performance 2GB DDR3-1333 240-Pin Module : CL9, 6-Layer PC Board, Life-Time Warranty X2
Thermaltake LitePower™ 500Watt, 8cm Low Noise Fan-2900R.P.M, ATX 12V 2.2, Dual +12V output circuit
Seagate® Barracuda™ 7200.12 Series - 500GB Serial ATA II (SATA2) Plus - Serial ATA 300 (3Gbps) With 16MB Cache @ 7200RPM - NCQ
SAMSUNG® BX2035 LED LCD - 20" Wide, 16:9 HD, 1600x900, 2ms Response Time, 5,000,000:1 Contrast Ratio, 250cd/m² Bright - D-SUB, DVI
GIGABYTE® X2 ATX Chassis - Black - Side Vented Panel - 4x 5.25" & 6x 3.5" Bays - Tool Free Design - 1x 120mm Fan - No PSU
I heard that its not good to put an i7 870 on an h55 board why? Im going to use onboard graphics for the moment and add a low end graphics card later there will be NO gaming, I heard that the onboard graphics is only on when you have an i3 or i5 is that true? and someone told me it was not advisable to use a gigabyte odin 585 watt PSU because its single rail is that true?
please i really need your help now urgently i have to order the PC today!
