Monitor Problem.PLEASE HELP!
Hello,I connected the DVI cord from the monitor to the comp,I tried all 4 sockets that it would fit and it will not turn on.I get a message that says "check signal cable".My monitor plugs into the video card not he motherboard.What should I do?
3 answers Last reply
More about monitor problem please help
  1. Check to see if your monitor has a manual Analog(VGA)/Digital(DVI) switch in it's menu options.
    -Wolf sends
  2. 1. Try another cable.
    2. Connect your monitor to a friend's PC to check the monitor
    3. Install your video in a friend's PC to check the video card
  3. Is the videocard powered properly?
Tuner Cards Graphics Cards DVI Monitors Motherboards Graphics
