Possible PSU issue and recommendations for replacement
Hi,
I bought a system a year ago and we've had intermittent errors with it from the first day. Having done some research on the company, it turns out that they have a terrible reputation for customer service and I can either pay to ship it back to them and then wait for months on end or fix it myself.
Kit:
GigaByte H55M-UD2H LGA1156, Cfire, DDR3, SATA2, mATX
Intel i5 750 2.66GHz LGA1156 Processor - Retail
4Gb (2X2Gb) Dual Channel DDR3 1333Mhz Memory
1024Mb ATi Radeon HD 5770 PCI-Express VGA Card
NEC AD-5240S-0B 24x+/-DVD-R SATA DL DVD Writer - Black
1TB Samsung Spinpoint F3 7200rpm S-ATAII 32MB Hard Drive
NZXT Beta Black ATX Gaming Case, No PSU
600W Silver SLI Ready 24Pin PSU
Problem:
System will reboot without warning. It can do this at any time, but you can usually force it to happen by doing something video-related, such as transcoding a DVD to DiVX, or watching something on a flash website.
Having had a browse on here I thought this might be heat related (I have the standard CPU cooling fan and the PSU has a fan but there is no case fan). Using Speedfan and OpenHardwareMonitor I checked the temps during video transcoding and the CPU temp notched up a bit before failing but only to around 50, which doesn't seem too bad. I also took the side panel off and ran a heavy fan at max speed but it still failed. I also bought an artic paste kit and replaced the thermal paste between the cooling fan/sink and the CPU with no effect.
So, I'm thinking it may be the PSU now. When I bought this the kit was delayed because they had difficulty sourcing the correct PSU. The one included is unbadged, it rattles a little and the instructions are minimal and badly translated, but I'm just working on a hunch - I don't know how to read the voltages on Open Hardware Monitor. I'll attach the report.
Going on the above, does anyone have any suggestions for further diagnosis and/or suggestions for a replacement PSU?
Thanks in advance,
bladesew
Quote:
Open Hardware Monitor Report
Version: 0.2.1.0
Common Language Runtime: 4.0.30319.1
Operating System: Microsoft Windows NT 6.1.7600.0
Process Type: 64-Bit
Sensors
+-+ Gigabyte H55M-UD2H (/mainboard)
| +-+ ITE IT8720F (/lpc/it8720f)
| | +- Voltage[0] : 0.896 : 0.896 : 1.024 : CPU VCore
| | +- Voltage[1] : 1.584 : 1.584 : 1.584 : DRAM
| | +- Voltage[2] : 3.44 : 3.376 : 3.504 : +3.3V
| | +- Voltage[3] : 5.05344 : 4.999681 : 5.08032 : +5V
| | +- Voltage[4] : 0.048 : 0.016 : 1.296 : Voltage #5
| | +- Voltage[5] : 3.072 : 3.056 : 3.088 : Voltage #6
| | +- Voltage[6] : 0.08000001 : 0.016 : 0.16 : Voltage #7
| | +- Voltage[7] : 8.505319 : 8.505319 : 8.505319 : +12V
| | +- Voltage[8] : 3.264 : 3.264 : 3.264 : VBat
| | +- Temperature[0] : 35 : 34 : 35 : Temperature #1
| | +- Temperature[1] : 25 : 25 : 25 : Temperature #2
| | +- Temperature[2] : 33 : 33 : 39 : Temperature #3
| | +- Fan[0] : 1380.368 : 1380.368 : 1530.612 : Fan #1
+-+ Intel Core i5 750 (/intelcpu/0)
| +- Clock[0] : 133.3326 : 133.3251 : 133.3405 : Bus Speed
| +- Clock[1] : 1199.994 : 1199.926 : 1999.997 : CPU Core #1
| +- Clock[2] : 1199.994 : 1199.926 : 1999.997 : CPU Core #2
| +- Clock[3] : 1199.994 : 1199.926 : 1999.997 : CPU Core #3
| +- Clock[4] : 1199.994 : 1199.926 : 1999.997 : CPU Core #4
| +- Temperature[0] : 44 : 43 : 50 : CPU Core #1
| +- Temperature[1] : 42 : 40 : 48 : CPU Core #2
| +- Temperature[2] : 41 : 41 : 48 : CPU Core #3
| +- Temperature[3] : 41 : 39 : 48 : CPU Core #4
| +- Load[0] : 1.158869 : 0.3896713 : 42.31062 : CPU Total
| +- Load[1] : 0.005078316 : 0 : 41.54144 : CPU Core #1
| +- Load[2] : 1.543462 : 0 : 43.07981 : CPU Core #2
| +- Load[3] : 0.005078316 : 0 : 50.67444 : CPU Core #3
| +- Load[4] : 3.081846 : 1.446265 : 74.63543 : CPU Core #4
+-+ ATI Radeon HD 5700 Series (/atigpu/0)
| +- Voltage[0] : 0.95 : 0.95 : 1.2 : GPU Core
| +- Clock[0] : 157 : 157 : 850 : GPU Core
| +- Clock[1] : 300 : 300 : 1200 : GPU Memory
| +- Temperature[0] : 40.5 : 40.5 : 42 : GPU Core
| +- Load[0] : 0 : 0 : 17 : GPU Core
| +- Control[0] : 40 : 40 : 40 : GPU Fan
+-+ SAMSUNG HD103SJ (/hdd/0)
| +- Temperature[0] : 26 : 26 : 26 : HDD
Parameters
| | +- Voltage[0] : CPU VCore
| | +- Ri [kΩ] : 0 : 0
| | +- Rf [kΩ] : 1 : 1
| | +- Vf [V] : 0 : 0
| | +- Voltage[1] : DRAM
| | +- Ri [kΩ] : 0 : 0
| | +- Rf [kΩ] : 1 : 1
| | +- Vf [V] : 0 : 0
| | +- Voltage[2] : +3.3V
| | +- Ri [kΩ] : 0 : 0
| | +- Rf [kΩ] : 1 : 1
| | +- Vf [V] : 0 : 0
| | +- Voltage[3] : +5V
| | +- Ri [kΩ] : 6.8 : 6.8
| | +- Rf [kΩ] : 10 : 10
| | +- Vf [V] : 0 : 0
| | +- Voltage[4] : Voltage #5
| | +- Ri [kΩ] : 0 : 0
| | +- Rf [kΩ] : 1 : 1
| | +- Vf [V] : 0 : 0
| | +- Voltage[5] : Voltage #6
| | +- Ri [kΩ] : 0 : 0
| | +- Rf [kΩ] : 1 : 1
| | +- Vf [V] : 0 : 0
| | +- Voltage[6] : Voltage #7
| | +- Ri [kΩ] : 0 : 0
| | +- Rf [kΩ] : 1 : 1
| | +- Vf [V] : 0 : 0
| | +- Voltage[7] : +12V
| | +- Ri [kΩ] : 27 : 27
| | +- Rf [kΩ] : 9.1 : 9.1
| | +- Vf [V] : 0 : 0
| | +- Voltage[8] : VBat
| | +- Ri [kΩ] : 0 : 0
| | +- Rf [kΩ] : 1 : 1
| | +- Vf [V] : 0 : 0
| | +- Temperature[0] : Temperature #1
| | +- Offset [°C] : 0 : 0
| | +- Temperature[1] : Temperature #2
| | +- Temperature[2] : Temperature #3
| +- Temperature[0] : CPU Core #1
| +- TjMax [°C] : 99 : 99
| +- TSlope [°C] : 1 : 1
| +- Temperature[1] : CPU Core #2
| +- Temperature[2] : CPU Core #3
| +- Temperature[3] : CPU Core #4
Mainboard
BIOS Vendor: Award Software International, Inc.
BIOS Version: F8
Mainboard Manufacturer: Gigabyte Technology Co., Ltd.
Mainboard Name: H55M-UD2H
Mainboard Version: x.x
SMBIOS Table
ABgAAAECAOADf4CayX8AAAAAMwX/////QXdhcmQgU29mdHdhcmUgSW50ZXJuYXRp
b25hbCwgSW5jLgBGOAAwMi8xMi8yMDEwAAABGwEAAQIDBAAAAAAAAAAAAABs8El0
PbkGBQZHaWdhYnl0ZSBUZWNobm9sb2d5IENvLiwgTHRkLgBINTVNLVVEMkgAIAAg
ACAAIAAAAggCAAECAwRHaWdhYnl0ZSBUZWNobm9sb2d5IENvLiwgTHRkLgBINTVN
LVVEMkgAeC54ACAAAAMRAwABAwIDBAICAgIAAAAAR2lnYWJ5dGUgVGVjaG5vbG9n
eSBDby4sIEx0ZC4AIAAgACAAAAQjBAABAwEC5QYBAP/7678DioUAoA/QB0EPCgAL
AP//BAUGU29ja2V0IDExNTYASW50ZWwASW50ZWwoUikgQ29yZShUTSkgaTUgQ1BV
ACAAIAAgACAAIAAgAAAFGAUABAQDAwoBAAEAAQQGAAcACAAJAAQgAAAGDAYAAR8A
AQALCwBBMAAABgwHAAEvAAIAf38AQTEAAAYMCAABPwABAAsLAEEyAAAGDAkAAU8A
AgB/fwBBMwAABxMKAAGAAUAAQAAgACAAAAICAkludGVybmFsIENhY2hlAAAHEwsA
AYEBAAgAICAAIAAAAgICRXh0ZXJuYWwgQ2FjaGUAAAgJDAABFgIA/1BSSU1BUlkg
SURFACAAAAgJDQABFgIA/1NFQ09OREFSWSBJREUAIAAACAkOAAEXAgChRkREACAA
AAgJDwABGAIIB0NPTTEAIAAACAkQAAEYAggHQ09NMgAgAAAICREAAQUCBQVMUFQx
ACAAAAgJEgAB/wIPDUtleWJvYXJkACAAAAgJEwABDwIPDlBTLzIgTW91c2UARGV0
ZWN0ZWQAAAgJFAABAAISEFVTQgAgAAAICRUAAQACEhBVU0IAIAAACQ0WAAEGBQME
AQAGBVBDSQAACQ0XAAEGBQMEAgAGBVBDSQAADRYYAAMAAAAAAAAAAAAAAAAAAAAA
AW58VVN8aXNvODg1OS0xAG58VVN8aXNvODg1OS0xAHJ8Q0F8aXNvODg1OS0xAGF8
SlB8dW5pY29kZQAAEA8ZAAMDAwAAAAL+/wQAIAAAERsaABkA/v8ACcwIAAgJAAEC
AgAANQUDBAUGQTAAQmFuazAvMQAgACAAIAAgAAARGxsAGQD+//////8AAAkAAQIC
AAAAAAMEBQZBMQBCYW5rMi8zACAAIAAgACAAABEbHAAZAP7/AAnMCAAICQABAgIA
ADUFAwQFBkEyAEJhbms0LzUAIAAgACAAIAAAERsdABkA/v//////AAAJAAECAgAA
AAADBAUGQTMAQmFuazYvNwAgACAAIAAgAAATDx4AAAAAAP//PwAZAAEgAAAUEx8A
AAAAAP//HwAaAB4AAQAAIAAAFBMgAAAAAAAAAAAAGwAeAAEAACAAABQTIQAAACAA
//8/ABwAHgABAAAgAAAUEyIAAAAAAAAAAAAdAB4AAQAAIAAAIAsjAAAAAAAAAAAg
AABAFiQA////////////bPBJAAA23ZFJIAAAfwQlACAAAA==
LPC IT87XX
Chip ID: 0x8720
Chip Version: 0x8
Base Address: 0x0290
Environment Controller Registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 13 10 00 00 FF FF 00 37 FF 87 60 0F 07 E9 FF 00
10 FF FF FF 36 D7 82 80 82 01 FF 00 FF FF FF FF FF
20 38 63 D6 BB 04 C0 01 86 CC 23 19 21 80 D9 65 65
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 74 2D 40 95 00 FF FF FF FF
50 FF 38 7F 7F 7F D0 59 59 90 59 03 12 60 00 00 00
60 00 0A 37 23 90 03 00 FF 00 14 41 23 90 03 00 FF
70 00 0A 37 23 90 03 00 FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 02 30 01 02 01 00 20 2E
90 FF 00 00 00 FF 00 00 00 FF FF FF FF FF FF FF FF
A0 C8 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
CPUID
Processor 0
Processor Vendor: Intel
Processor Brand: Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
Family: 0x6
Model: 0x1E
Stepping: 0x5
CPUID Return Values
CPU Thread: 0
APIC ID: 0
Processor ID: 0
Core ID: 0
Thread ID: 0
Function EAX EBX ECX EDX
00000000 0000000B 756E6547 6C65746E 49656E69
00000001 000106E5 00100800 0098E3FD BFEBFBFF
00000002 55035A01 00F0B0E4 00000000 09CA212C
00000003 00000000 00000000 00000000 00000000
00000004 1C004121 01C0003F 0000003F 00000000
00000005 00000040 00000040 00000003 00001120
00000006 00000001 00000002 00000001 00000000
00000007 00000000 00000000 00000000 00000000
00000008 00000000 00000000 00000000 00000000
00000009 00000000 00000000 00000000 00000000
0000000A 07300403 00000044 00000000 00000603
0000000B 00000001 00000001 00000100 00000000
80000000 80000008 00000000 00000000 00000000
80000001 00000000 00000000 00000001 28100800
80000002 65746E49 2952286C 726F4320 4D542865
80000003 35692029 55504320 20202020 20202020
80000004 30353720 20402020 37362E32 007A4847
80000005 00000000 00000000 00000000 00000000
80000006 00000000 00000000 01006040 00000000
80000007 00000000 00000000 00000000 00000100
80000008 00003024 00000000 00000000 00000000
CPU Thread: 1
APIC ID: 2
Processor ID: 0
Core ID: 1
Thread ID: 0
00000001 000106E5 02100800 0098E3FD BFEBFBFF
0000000B 00000001 00000001 00000100 00000002
CPU Thread: 2
APIC ID: 4
Processor ID: 0
Core ID: 2
Thread ID: 0
00000001 000106E5 04100800 0098E3FD BFEBFBFF
0000000B 00000001 00000001 00000100 00000004
CPU Thread: 3
APIC ID: 6
Processor ID: 0
Core ID: 3
Thread ID: 0
00000001 000106E5 06100800 0098E3FD BFEBFBFF
0000000B 00000001 00000001 00000100 00000006
Intel CPU
Name: Intel Core i5 750
Number of Cores: 4
Threads per Core: 1
Timer Frequency: 1.953115 MHz
Time Stamp Counter: Invariant
Time Stamp Counter Frequency: 1999.99 MHz
MSR Core #1
MSR EDX EAX
000000CE 00000900 40030F00
00000198 00000000 00000009
0000019C 00000000 88360000
000001A2 00000000 00631000
MSR Core #2
MSR EDX EAX
0000019C 00000000 88380000
MSR Core #3
MSR EDX EAX
MSR Core #4
MSR EDX EAX
0000019C 00000000 883A0000
AMD Display Library
Status: OK
Number of adapters: 3
AdapterIndex: 0
isActive: 1
AdapterName: ATI Radeon HD 5700 Series
UDID: PCI_VEN_1002&DEV_68B8&SUBSYS_22881787&REV_00_4&932E434&0&0018A
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB06100
AdapterIndex: 1
isActive: 0
UDID: PCI_VEN_1002&DEV_68B8&SUBSYS_22881787&REV_00_4&932E434&0&0018&02A
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB06100
AdapterIndex: 2
isActive: 0
UDID: PCI_VEN_1002&DEV_68B8&SUBSYS_22881787&REV_00_4&932E434&0&0018&03A
Present: 1
VendorID: 1002
BusNumber: 1
DeviceNumber: 0
FunctionNumber: 0
AdapterID: 0xB06100
S.M.A.R.T Data
Drive name: SAMSUNG HD103SJ
ID RawValue WorstValue AttrValue Name
1 39 00 00 00 00 00 100 100 ReadErrorRate
2 00 00 00 00 00 00 252 252 ThroughputPerformance
3 4B 1E 00 00 00 00 70 75 SpinUpTime
4 71 00 00 00 00 00 100 100 StartStopCount
5 00 00 00 00 00 00 252 252 ReallocatedSectorsCount
7 00 00 00 00 00 00 252 252 SeekErrorRate
8 00 00 00 00 00 00 252 252 SeekTimePerformance
9 CE 17 00 00 00 00 100 100 PowerOnHours
10 00 00 00 00 00 00 252 252 SpinRetryCount
11 01 00 00 00 00 00 100 100 RecalibrationRetries
12 71 00 00 00 00 00 100 100 PowerCycleCount
191 00 00 00 00 00 00 252 252 191
192 00 00 00 00 00 00 252 252 192
194 1A 00 0F 00 23 00 64 64 Temperature
195 00 00 00 00 00 00 100 100 HardwareECCRecovered
196 00 00 00 00 00 00 252 252 ReallocationEventCount
197 00 00 00 00 00 00 252 252 CurrentPendingSectorCount
198 00 00 00 00 00 00 252 252 UncorrectableSectorCount
199 00 00 00 00 00 00 200 200 UltraDMACRCErrorCount
200 24 14 00 00 00 00 100 100 WriteErrorRate
223 01 00 00 00 00 00 100 100 223
225 73 00 00 00 00 00 100 100 225
6 answers Last reply
More about possible issue recommendations replacement
  1. Oh also - I have checked the memory with memtest. You can also get it to fail by running the CPU tests in Prime95, but as I said the system runs okay if you don't put it under strain so maybe not cpu related?
    I've been working away from home so have only just started looking at this.
  2. From what you describe i would say it's a video driver issue and or memory related..
    Is the onboard video disabled?
    What version of CCC are you using?
    Sometimes rolling back a version or two helps with stability.
    Thanks for the reply. I've checked the ram with memtest - no problems there.
    Also, I thought that streaming flash video uses the CPU (at least it does if you have hardware accelaration disabled, which I do). Also, running prime95 CPU tests cause reboot, which shouldn't depend on video card?
    I'll check CCC version though. I seem to remember that the DVD the driver came with has a problem when installing on windows 7, so I have whatever drivers came pre-installed.
  4. This is the CCC version:
    Catalyst™ Control Center Version 2009.0918.2132.36825
  5. Trying to update CCC or even just the display drivers fails on this machine - get a message saying that windows have applied compatability settings but fails on subsequent runs too. FYI - running windows 7 64-bit.
  6. Go to add/remove and dump whatever ATI software is there
    Download Driversweeper
    http://phyxion.net/item/driver-sweeper.html
    Run DS in safemode
    Check off AMD
    Analyze and clean
    Restart normal
    Go to AMD and install latest CCC as ADMIN
Power Supplies Components
