G
Guest
Guest
Budget Range: 750-800
System Usage from Most to Least Important: Gaming – FPS, web
Parts Not Required: keyboard, mouse, speakers, hard drive
Preferred Website(s) for Parts: newegg, others
Country of Origin: US
Parts Preferences: none
Overclocking: No
SLI or Crossfire: No
Monitor Resolution: 1920x1080 or lower
How does this build look, guys?
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk – OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
16.99
ASUS VH236H Black 23" 2ms(GTG) HDMI Widescreen Full HD 1080P LCD Monitor 300 cd/m2 20000 :1 (ASCR) Built-in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
179.99 (159.99 with rebate)
XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150477
209.99 (179.99 w/ rebate)
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
79.99 w/ $10 off promo (59.99 w/ rebate)
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
59.99
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.564585
COMBO
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor HDZ955FBGMBOX
GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
219.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.546483.11-147-153
COMBO
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Rosewill CHALLENGER Black Gaming ATX Mid Tower Computer Case
144.98
TOTAL: 911.91 + 10 Gift card (841 after rebates)
Is there a way to bring the build price down a bit without losing quality? close to 800 would be good. I see the athlon II x4 640 as a good budget gamer CPU in a lot of builds. Am I getting a better deal with the phenom II x4 955 BE or should I get the 640?
Overclocking: No
16.99
59.99
COMBO
219.98
COMBO
144.98
