Hi guys, i need some serious help. I will explain my problem in gr8 detail.
Ok, i just got my new PC with 2600K as CPU, 590GTX as GPU and Asus Maximux IV Extreme MB. I have 4 ram sticks of 4GB each. Ok now i have a problem with the ram.
My ram sticks came from 2 diffrent places but they are the same model. 4 of them are G-Skill Ripjaws model.
2 of the sticks are; F3 - 1700 CL9D-8GBXLD (DDR3 2133 CL9-11-9-28 1.65V PC3-1700 4GBX2)
The other 2 are; F3 - 1700 CL9D-8GBXLD (DDR3 2133 CL9-11-9-28 1.65V XLD-1700 4GBX2)
Ok now, i have win7 64 bit. When i plug the rams into 2-3-4 sockets they all work fine at 12GB mem but at 1.3 speed.
When i plug just 2 rams in sockets 2-3 3-4 2-4 they work fine and i can OC for 2.133 speed.
When i plug 2 rams into slots 1-4 1-3 1-2 system boots but it shows only 4gigs of ram, meaning just the ram at the other slot.
When i plug 3 rams with diffrent slot combinations of 1-2-3 1-2-4 1-3-4 system again doesnt boot.
When i plug 4 of them together, system wont boot and i get an E2 error on led meaning Memory Initialization problem.
When i just plug a single ram into the 4th slot, i get error 53 on led which also means memory initialization problem , invalid memory type or speed.
I am thinking slot 4 is broken or something? It is a brand new MB out of the box. It works quite nicely apart from this. PPL have been saying check if the rams are seated so i am guessing maybe something is bent in the 4th slot inside or maybe there a little piece blocking the ram from totally seating inside.
Any ideas guys, i really dont want to send the MB to the place i bought the PC, it will take a week for it to come back and i have a CPU Cooler Block which we all know is a PAIN IN THE ASS to be inserted again.
I am using the PC with 8 gigs of ram at slots 2-4 atm. Awaiting your answer, plz help me tonight i want to sleep peacefully.
