Headphones don't work need help!
Hello,
I connect the headphones to the light green outlet but i get no sound. I used to get sound
2 answers Last reply
More about headphones work help
  1. Have you tried plugging-in a different set of known good headphones? This will tell you whether your headphones are bad, or whether you have a bad case connector.
  2. 108399 said:
    Hello,
    I would also suggest
    - Bring up the volume control and ensure that it is not muted or low.
    - Check the Device Manager to see that you have a known Sound device. In infrequent cases, you can see a yellow exclamation point instead if the drivers are not properly installed.
    - You didn't mention what system you have. Some of the more advanced mobo audio can dynamically remap the outlets to different functions. I doubt that this is your problem, but it is a possibility.
    I hope that this helps
Prebuilt Light Connection Headphones Green Systems
