How much spare power does my PSU have?
I'm considering upgrading my Video card (currently integrated) but my PSU is really low powered (220w), however Ive spoken to people who say running a HD5570 card will be fine on the PSU, I want to be sure before I do anything though.
Is there anyway to find out how much spare power my PSU has or how much each component is using?
5 answers Last reply
More about spare power have
  1. yes their is, but don't put all your faith in just one calculator. The above posted is one of my favorites, but their are many others. What kind of PSU are you using right now? what cpu? how many hdds, o.d.s, etc. keep in mind that if the power supply isnt 80 plus certified, then you wont see even 80% of its rated power at full strain. And the longer you've had the psu, the more degraded it will be and the less output you'll get. I just had this same dilemma with my system. The best place to start would be to list your computer specs. We can figure it out from there
  2. If a PSU isn't 80+ certified, assume 70% efficency.
    So 70% of 220w is only about 154w, to put that in perspective.
    So no, I wouldn't try using ANY dedicated PCI-E GPU with that PSU.
  3. AMD athlon II X3 435 - 2.90GHz
    4GB RAM
    2 500GB HDD's (don't know how to find out speed)
    nvidia 9200
    Not to sure how to find out other information.
    My PSU is a really stange shape and my case is very unforgiving, here is a pic of it:
    http://i1133.photobucket.com/albums/m600/Ichis_Ghost/GEDC0018.jpg
    OCZ SXS 600w
    Not 80+ certified, does provide 80+ efficiency.
    And was able to provide almost 23% more power than it's rated for, not 20% less.
    http://www.hardwaresecrets.com/article/451
    There's some good info here
    http://www.jonnyguru.com/modules.php?name=NDFAQs
Power Supplies Graphics Cards Power Components
