Any problems with this build?
3 answers Last reply
More about problems build
  1. I dont know where your from so recommending parts might be harder.
    1) you dont need a x6 if your gaming. Id recommend the 955be.
    2) pick a better hdd like the spinpoint f3 1tb or caviar black 1tb
    3) 650w will be enough for 460 sli
    4) if your overclocking you cpu consider a cooler like the hyper 212+
  2. Hmm, ok, but is there any reason why I should take the 955 instead of say... the 970? o.O
  3. They are the exact same chip, the only difference is the the 970 is clocked higher in the factory. So you can overclock the 955 to the same level as 970 very easily.
Build Systems
