Asrock M3A770DE sound issue
Last response: in Components
Related ressources:
- ForumM3A770DE Audio Driver Issue
- ForumOC Settings for amd 955 be and a asrock M3A770DE
- ForumASRock M3A770DE - Won't POST/Boot
- ForumOpen box ASUS M4A785TD-V EVO or ASRock M3A770DE
- ForumIssue with ASrock m3a770de and eSATA
- ForumASRock M3A770DE won't boot with more than one stick of memory
- ForumM3A770DE will not move past POST to Windows XP
- ForumWill this Crucial memory work on an ASRock M3A770DE
- ForumASRock M3A770DE and OCZ DDR3 1066
- ForumHelp! Asrock z68 Extreme4 Instant Flash problem.
- ForumOpinions and price of this PSU...........
- Forum[Solved] No sound after boot
- ForumPossible PSU issue and recommendations for replacement
- Forum[Solved] sound card and onboard audio,both enabled question
- ForumShould I have three sound cards installed?
- Forum[Solved] Will front audio ports use sound card quality? Best sound card?
- ForumA Potential Cpu Issue? FPS In Games
- ForumBest sound card for my situation
- ForumRealtek high definition audio sound card
- More resources
Read discussions in other Components categories
Motherboard: Asrock M3A770DE, installed drivers from CD. There is a speaker on the notification bar and when I hover the mouse over it, it says, 'Digital Audio (S/PDIF): 100%'. I have just a normal 2 channel speaker setup and can't hookup to that plug. How the heck do I change it so that the sound comes out the lime green plug? I'm running Win 7 HP x64.
