Hey guys, need help yet again.
First off thanks to all who helped me pick my build.
First comp went off without a hitch and is pretty awesome at the store.
The 2nd one is having issues booting.
Put all the parts together, booted up fine. Installed Win 7 was fine. Installed motherboard drivers and was fine. Ran prime for another an hr. I forgot to check temps but checking the motherboard during first boot CPU was reading 25 degree's C. The i7 with the Zalman was running around 35 degrees C.
Plugged in ethernet cable and system went down.
Tried starting it back up and motherboard doesn't seem to get power. CPU fan doesn't blow.
Put in motherboard speaker and nothing. Tried another PSU and nothing.
I'm hoping I don't have to RMA so any other suggestions will be great. I also tested the motherboard with a GT430 and no go either. Swapped RAM around and even tried running off one.
I'm going to try to reseat the CPU and reinstall the 212+ again but I'm at my wits end.
Specs below
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
GIGABYTE GA-870A-UD3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128443
Sony Optiarc CD/DVD Burner Black SATA Model AD-7260S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118039
COOLER MASTER Hyper 212 Plus RR-B10-212P-G1
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Enzotech MST-88 C1100 Forged Copper Heatsink
http://www.newegg.com/Product/Product.aspx?Item=N82E16835708016
XFX HD-687A-ZNFC Radeon HD 6870
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150506
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
COOLER MASTER RC-692-KKN2 CM690 II Advanced
Specs below
