My current powersupply only have 2x 6 pin connectors, And i find that limiting me from the cool ass graphics cards. Are there any top cards that will only need 2x 6 pin connectors?
You can get a 6pin to 8pin adapter for cards that just want a single 8 pin connector which seems to be your problem, they tend to prefer a single 8 pin over 2 6pins because it provides the same amount of power but wastes less board space. Since you have 2 6 pins you know your PSU can handle a single 8 pin so you would be fine using one of these adapters if you need to http://www.newegg.com/Product/Product.aspx?Item=N82E16812201028&cm_re=8_pin_6_pin-_-12-201-028-_-Product
