Okay, this has been driving me crazy.
I have a home built system running Windows 7 32 bit. The computer was built about 5 months ago and I started having issues about 3 weeks ago.
My computer will randomly shut off and won't power on right away. Sometimes it'll be running xbmc and other times I'll just be browsing the internet and it shuts off. Nothing happens if I hit the power button. I have to either wait 5 minutes or I have to switch the power off on the power supply and turn it back on.
Sometimes, it'll turn back on by itself after about 15 minutes and I notice that the system time gets behind by 15 minutes.
The event logs say 'the previous shutdown was unexpected' but I don't see other entries that describe any problems.
I have the power options set to where it doesn't go to sleep automatically.
During idle, the CPU and Motherboard temps are around 40 to 50 degrees celsius.
Under 100% load (using prime95) the temps go to about 75-80 celsius.
I've run Windows memory test and it goes through without any errors.
I've also tried 2 different power supplies and get the same results. Do I have a bad motherboard or is my cpu running too hot?
I've also read that it may be my voltage settings in the Bios that is causing issues.
Here are my computer specs:
nMEDIAPC Black Aluminum / Acrylic / Steel HTPC 5000B Micro ATX Media Center / HTPC Case
GIGABYTE GA-H57M-USB3 LGA 1156 Intel H57 HDMI USB 3.0 Micro ATX Intel Motherboard
CORSAIR CMPSU-450VX 450W ATX12V V2.2 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
Intel Core i3-530 Clarkdale 2.93GHz LGA 1156 73W Dual-Core Desktop Processor BX80616I3530
G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model F3-12800CL9D-4GBNQ
Western Digital Caviar Green WD10EARS 1TB 5400 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
