Hi all, I today received 8GB Ripjaws memory, it's currently running in my system. Prior to this I had 4gb running fine. I've looked at the manual and followed the pairing, but I'm unable to run both at the same time.
With all 4 modules in, the computer turns on, but doesn't beep (as normal) and the major issue is that no video is outputted, so I am unable to enter BIOS with all 4 in.
The two new modules have been through a diagnostic test and are perfectly fine, the 2 modules I had before hand are also fine and have been for 2+ years.
Bear in mind my motherboard can handle 16gb (M4A77TD PRO) I'm curious as to what the issue is, I can run them separately, so either 4gb or 8gb, but I am unable to have both pairs working simultaneously?
I am assuming this is due to BIOS settings for the 8gb set being better than the 4gb, but would like to clarify this before I start changing things.
Is a BIOS update a potential fix too?
Thanks.
Thanks.
