Ordering a Build Today please urgent help
So my Friend is buying a $600 gaming pc. I have the parts chosen for him and here is what i got so far.
ODD http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
HDD http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
GPU(Fishy) http://www.newegg.com/Product/Product.aspx?Item=N82E16814131386
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
Case+Mobo http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.567750
Ram + CPU http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.570491
So can you asnwer some questions about it.
1. Is everything compatible with itself?
2. Does the graphic card look fishy becuz its so cheap
3. Any other suggestions?
3 answers Last reply
More about ordering build today urgent help
  1. seems good.
    i'll just post a rig so you can compare :)
    if its just gaming, go for more juice at the gpu.
  2. well for your build you have a triple core athlon that would bottleneck the 6850 and isnt 5850 same as 5850 if not better
  3. would it really bottleneck? most game tend to use 2 to 3 cores. with your budget this should be the cpu your getting. and the 6850 is not same with the 5850!
    read THIS
New Build Systems Product
