Ok so I just finished building my first PC. I hooked everything up in the room I had assembled it in and it worked great. I was able to get into the BIOS and look around, but I didn't change anything.
I wanted to hook it up in my room, so I hauled it over and very gently set everything up. At first I attempted to power it up, but got nothing. I opened it up and secured the 8 and 24 pin connectors on the motherboard. Now it starts up for a couple of seconds, powers down, then restarts itself and just runs as if it's on, but I'm not getting any video. My monitor just says "No HDMI found" and goes back to sleep as if nothing is plugged into it. My video card LEDs come on and everything APPEARS normal in the case. When it's in this state, I cannot power it down via the power button either, I have to shut the PSU off.
If you want video, I can record something real quick to show you. But I think I explained it clearly enough. Please help, I'm so stressed from work right now and I just want to play some games!
Mobo: Asus Maximus III Formula
GPU: Gigabyte GTX 470 SOC
CPU: Intel i5 760
PSU: Corsair TX850W
CPU: Intel i5 760
PSU: Corsair TX850W
