Solved
Help me choose a new case for my build! =D
Last response: in Systems
Gift cards ftw xD
I've got some extra dough and the need for a new case. =]
Looking at these three:
http://www.bestbuy.com/site/Antec+-+Nine+Hundred+II+Com... nine&cp=1&lp=1
http://www.bestbuy.com/site/Thermaltake+-+V9+Black+Edit... black &cp=1&lp=1
http://www.bestbuy.com/site/Cooler+Master+-+690+11+Adva... II&contract_desc=null
For now I'm doing air cooling, but a brand new H70 would only be $80!
So the case would have to support water cooling for the future.
This will be mostly used for gaming and a full tower is out of the question atm or I'd buy the Phantom.
Please recommend me a case? Tell me experiences you've had with them!
Thanks in advance,
- Matt
More about : choose case build
Related ressources
I can vouch for the Antec Nine Hundred II, cause I have it. IT IS AMAZING. Cable management, airflow, looks, are all flawless. I wouldn't recommend any other mid-tower in it's price range over this one. It can support an H50 and an H70, but the H70 might be a little cramped. Then again, it would be cramped in any mid-tower case.
joelmartinez said:
If design is what you want get an NZXT tempest evo can't find it on best buy newegg link below:
NZXT phantom http://www.newegg.com/Product/Product.aspx?Item=N82E168...
NZXT apollo http://www.newegg.com/Product/Product.aspx?Item=N82E168...
and many more, sell your gift cards to a friend and buy from newegg :D
I would love to buy the Phantom and probably will next year, but this year I'm choosing between those three.
Thank you though.
Ask the community
