L luckychalmz Distinguished Mar 12, 2011 63 0 18,640 Mar 21, 2011 #1 Would I be okay using a 850W - 950W with two GTX 580's and still be able to run multiple other things in my rig?
L luckychalmz Distinguished Mar 12, 2011 63 0 18,640 Mar 21, 2011 #2 ct1615 : depends on the PSU, if they are solid then yes. if they are budget ones then no. http://www.newegg.com/Product/Product.aspx?Item=N82E16817371012 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139007 http://www.newegg.com/Product/Product.aspx?Item=N82E16817341045 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151102 http://www.newegg.com/Product/Product.aspx?Item=N82E16817256057 http://www.newegg.com/Product/Product.aspx?Item=N82E16817256067 http://www.newegg.com/Product/Product.aspx?Item=N82E16817207001 Would any of these be able to support two GTX 580s and then some. Upvote 0 Downvote
clarkjd Splendid Dec 7, 2005 6,486 34 28,490 Mar 21, 2011 #3 I think you would be happy with any one of them. They are all good brands. If you are really paranoid, go with one of the 1KW models. Upvote 0 Downvote
L luckychalmz Distinguished Mar 12, 2011 63 0 18,640 Mar 21, 2011 #4 Is OCZ a good brand? Right now that's the cheapest one out of all those when it comes to the 1000W. Upvote 0 Downvote
L luckychalmz Distinguished Mar 12, 2011 63 0 18,640 Apr 5, 2011 #5 Best answer selected by luckychalmz. Upvote 0 Downvote
