Need opinions on quiet work pc
Last response: in Systems
I would like to build a quiet pc for web programming, office apps etc. (ie non-gaming, non-HTPC). I plan to run Win 7 pro as host and GUI Linux VM for web site local development.
Below are some specs provided by a local store.
Case - Fractal R3
PS - Seasonic M12II 520W
CPU - Intel i5 960 + Corsair A50 fan
MB - Asus P7P55D-E LX
RAM - OCZ DDR3-1333 2x2GB
HDD (Boot - Corsair F60GB SSD, Data - Seagate Barracuda 7200.12 1TB)
GPU - Asus Radeon 5450
Monitors - 2 x LG W2243T (24")
KB/Mouse - MS Wireless Desktop 3000 Bluetrack
I have a few questions:
1. Is there another case you'd also recommend?
2. Would a Seasonic X-400FL (400W fanless) PS put out enough power for this system?
3. Is 4GB RAM enough for Windows 7 and a couple of 1GB VMs?
4. Is 60GB boot enough for Windows 7 and all the inevitable service packs etc.
5. Assuming 60GB is plenty for the boot drive is it worth trying to squeeze a 20GB linux VM on the boot drive as well or should I just leave it on the Seagate?
6. I've read the Seagate drives can be noisy - would a WD Green better and offer adequate performance?
7. Is the Radeon adequate or overkill for my basic graphics needs?
Thanks
More about : opinions quiet work
If not gaming, I'd choose about any ATI/AMD PCI-e video card you can get your hands on for $50 or less...
I'd stick with original PSU, I prefer not to push a power supply beyond 60-70% of it's rated capacity...; more of a margin as it ages over the years.
Related ressources
Samsung HDDs are very quiet. There's even a setting somewhere to make them quieter.
I've also had good (quiet) results with Seasonic PSUs and Scythe coolers. The normal (fanned) Seasonics are very quiet so I don't think you'll need a fanless model. It won't hurt though if it's within budget.
You probably don't need a graphics card. Onboard has been plenty powerful for what you want for years - at least on the AMD platform, not so sure about Intel.
A cheap case can be a major source of noise. last computer I put together had carefully chosen quiet parts but vibrations from the HDDs made the case resonate with a droning sound. Next build I think I'll just make one out of wood.
That LGA 1366 CPU (if i7 960) is incompatible with that LGA 1156 mobo @@
If u live near a Microcenter:
1055T + Gigabyte 880G mATX and HD 4250 IGP @ $225?
http://www.microcenter.com/specials/promotions/AMDbundl...
IGP does fine for non gaming dual display and with a Radeon class GPU scales for up to 4 displays via ATI Surround View feature
http://hardforum.com/showthread.php?t=1390782
As for your other questions:
1. APEX mATX?
2. Antec 380 80+ Bronze?
3. If VM is heavy hit 8GB DDR3?
4. Good to go
5. Your call
6. Actually if u need cheap, big storage mechanical have a look at Samsung F4 2TBs?
7. An IGP from 2008/780G or better would suffice ^^
Ask the community
