This will be my very fist custom case, so I'm kind of new to the whole computer case scene.
As the title suggest, I'm looking for full tower case that's the best when it comes to air cooling. I don't know what the pros and cons are to aluminum vs. plastic, but I do feel (literally) that aluminum is better quality. But I guess you guys are the pros, so I'll leave it up to you. Either or is fine.
I don't care about hot-swappable bays, open case/see-through case, LED lights, etc.; all that extra ****. I just want the best cooling there is. Oh, and USB 3.0.
I'm willing to spend anywhere from $100-$225, preferably in the lower range. Best bang for my buck would be ideal.
Thanks in advance.
Thanks in advance.
