So after a long time, I finally mustered the courage to dive into building my own machine. After reading a WHOLE bunch on various parts and options, I arrived at the following build. I'm mainly looking for verification as to whether the parts actually function together. Suggestions for better or alternate parts are appreciated.
Case
Rosewill CHALLENGER Black Gaming ATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
54.99
Hard Drive
Seagate Barracuda 750GB 7200 RPM SATA 3.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148445
59.99
VGA
HIS H577FK1GD Radeon HD 5770 (Juniper XT) 1GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161338
129.99
PSU
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
69.99
RAM
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
49.99
Mobo
GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard (1600)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128412
139.99
CPU
Intel Core i5-760 Lynnfield 2.8GHz LGA 1156
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115067
204.99
TOTAL COST: $709.93 + $3 shipping
Ultimately, I settled on a the i5 760 as a best fit for me amongst Intel processors. From there, I went to the Mobo that was "futureproof" with crossfire capability (though I doubt I'll use it).
RAM seemed straightforward, I chose the 1600, but I'm not sure if it's a better or worse pick over 1333.
I went with a safe 600W since it's just $5 more than the 500W, but I hear Corsair is better but not modular. However, was unsure which to pick, if at all.
With respect to VGA - I don't need the best of the best, and 5770 seemed to be recommended. I'm perhaps the least sure of this choice, any explanation/guidance would be great. Ideally, I'd have a card that runs most games above average/exceptionally.
Picked seagate HDD simply because I have had 'em in the past and was pleased. Is there a better option?
Case seemed like a good "bang-for-your-buck" option.
Also, will I need to purchase any sort of cooling unit? I may OC in the future... but I'm not sure how tangible the differences would be. I'd like to keep it an option, at the very least.
Thanks for your time!
Case
54.99
Hard Drive
59.99
VGA
129.99
PSU
69.99
RAM
49.99
Mobo
139.99
CPU
204.99
