Where is the problem in this config
Last response: in Systems
Hello,
Friend of mine has got a problem with configuration (recommended by myself), a lot of windows blue screens (one every 30-40min)
usually referring to:
BAD_POOL_HEADER
and
MEMORY_MANAGEMENT
List of components:
(CPU+MOBO+MEMORY+COOLER)
**OVERCLOCKED** Motherboard Bundle (GA-X58-USB3 Motherboard + i7-930 CPU (O/C @ 3.6Ghz) + 6Gb DDR3 1600Mhz Memory + OCZ Gladiator CPU Cooler)
GRAPHIC CARD
MSI GeForce GTS 450 1GB GDDR5 PCI-E 2.0 x 16 Graphics Card (N450GTS CYCLONE 1GD5/OC)
PSU
OCZ ModXStream Pro 700W Modular Active PFC Power supply
HARD DRIVE
SPINPOINT F4 320gb 7200RPM SATA
I need to mention that I have tried different memory configurations (changed them around in slots as recommended on mobo manual).
I have formatted hard drive and reinstalled windows with all latest drivers.
Restored default bios settings
System was taken to the store, they have tested it for 24hrs without fail...
anyone any ideas, I am pretty close to returning it back to the store
More about : problem config
Related ressources
Possibly hardware error. Unfortunately the diagnosis is an elimination process. There are only 4 items that could be defective: CPU, mobo, memory, or HDD. My gut feeling says it is a bad mobo.
Memory is easy to diagnose: just run memtest. SMART errors on HDD can cause BSOD. So for HDD just use another one.
Try one RAM stick at a time, and run Memtest on it. One stick may be flaky.
Somewhat less likely, but still possible, you could also have a bad PSU, that is spiking your system or otherwise out of spec.
Ask the community
